STAR Rigid Body Motions Returning Zero
  • February 22, 2024
  • 99 views
tpotter6
Hello!
I have been running into an issue where I am trying to extract rigid body motion information from the STAR fit, but have only been getting zeros out. I am running a Python Interactive Extension using a notebook. Terminating the session and looking at the Fit Assessment, I can see the values, but have been unable to access them in Python.
This behavior looks to be repeated in this example:
I can see that though some of these angles have a negative sign, the only value displayed is 0.0. Is the data being truncated somewhere, or am I trying to pull data incorrectly? I have included a working example in the attachment.
Thank you,
Thad
Best answer by Matthias.Schlich
Hi Thad,
Thank you for your interest in STAR.
There is a command to retrieve the RBM information in the API, which needs to be used before accessing the angles and decenters:
surface.STARData.Deformations.RBMs.GetTransformValues()
After that, you should be able to retrieve the same values as in the UI with the API commands mentioned in the post that you linked.
I hope that this solves your issue.
Best regards
Matthias
Matthias.Schlich
Hi Thad,
Best regards
Matthias
tpotter6
  • February 23, 2024
Hi Matthias, thank you for the response!
That solved the issue. Must have missed that in the documentation and examples.
Thad
