Paper out: modelling residual polarization ellipticity in OpticStudio
  • Nov 15, 2026 1:29 PM UTC
  • 38 views
Hi all,
I wanted to share a small paper that this community played a part in. I knew ​@Jeff.Wilde  through the forum, so when I got stuck trying to understand some polarization measurements, I knew he’d be a good person to ask. He kindly offered to help, and he ended up as a co-author.
The paper is about trying to reproduce a waveplate compensation method for polarization-resolved SHG microscopy. It didn’t work as well for us as expected: some residual ellipticity remained that we couldn’t get rid of. We used OpticStudio to explore why. A possible explanation is that the dichroic mirror’s retardance depends on wavelength, and a femtosecond pulse is broad enough that no single waveplate setting corrects all of it.
Some parts that might interest people here:
  • Linear retarders modelled as Jones matrix surfaces, with ZPL macro solves for each matrix element
  • Waveplate angles swept through the ZOS-API using ZOSPy (​@chaasjes, ​@jwbeenakker)
  • Polychromatic behaviour approximated by summing intensities from 15 wavelengths
The OpticStudio files and Python code are on GitHub, in case they’re useful to anyone:
https://github.com/Omnistic/residual_ellipticity_in_pshg_simulations
Paper (open access): https://doi.org/10.1371/journal.pone.0357256
Thanks again, Jeff, and thanks to this community for the connections it makes possible.
  • Nov 16, 2026 5:45 AM UTC
Thanks for the shout-out David!  It was a pleasure working with you.  The publication should prove very helpful to those working on pol-resolved SHG microscopy.
Looking forward to more of your insightful posts on the forum!
This is excellent work, David and Jeff. I have to admit being rather pleased at how well Zemax modeled this system. I do have a couple of questions on the Zemax modeling side though:
1. I presume you modeled the SHG source at its own wavelength, i.e. the wavelengths were the frequency doubled wavelength?
  1. Did you try modeling the spectral bandwidth of the femto second pulse using either multiple wavelengths with appropriate weights, or by using multi-configs to scan the wavelength?
  2.  How was the quarter wavelplate modeled? From my reading of the paper you used the Jones matrix, but were you able to use the birefringent In/Out surface?
  3. Birefringence is one area where the non-sequential model is actually better than the sequential. In sequential mode you have to use configurations for each polarization, and then add across configurations. In NS mode, the birefringent model is actually easier and more directly physical: you don’t need to use configurations at all. If you save to a ray database you should be able to see the retardation applied to each ray individually
  • I hope this helps and doesn’t just cover stuff you already tried :-) And again, well done on a great simulation
    Mark
