Paper out: modelling residual polarization ellipticity in OpticStudio
  • Nov 15, 2026 1:29 PM UTC
  • 4 views
Hi all,
I wanted to share a small paper that this community played a part in. I knew ​@Jeff.Wilde  through the forum, so when I got stuck trying to understand some polarization measurements, I knew he’d be a good person to ask. He kindly offered to help, and he ended up as a co-author.
The paper is about trying to reproduce a waveplate compensation method for polarization-resolved SHG microscopy. It didn’t work as well for us as expected: some residual ellipticity remained that we couldn’t get rid of. We used OpticStudio to explore why. A possible explanation is that the dichroic mirror’s retardance depends on wavelength, and a femtosecond pulse is broad enough that no single waveplate setting corrects all of it.
Some parts that might interest people here:
  • Linear retarders modelled as Jones matrix surfaces, with ZPL macro solves for each matrix element
  • Waveplate angles swept through the ZOS-API using ZOSPy (​@chaasjes, ​@jwbeenakker)
  • Polychromatic behaviour approximated by summing intensities from 15 wavelengths
The OpticStudio files and Python code are on GitHub, in case they’re useful to anyone:
https://github.com/Omnistic/residual_ellipticity_in_pshg_simulations
Paper (open access): https://doi.org/10.1371/journal.pone.0357256
Thanks again, Jeff, and thanks to this community for the connections it makes possible.
