Lens or surface notation
  • Sep 11, 2025 6:57 AM UTC
  • 149 views
eyal.dekel
Is there a way to add a surface or lens notation (names) in the 3D layout analysis?
Automatically, not drawing manually.
Something similar to CODE V.
Eyal
​@eyal.dekel
As far as I know, there isn’t such an automatic feature.
I don’t know how CODE V does it, but here ​@MichaelH has been doing a lot of work in that direction using a ZPL Macro:
Perhaps you could draw inspiration from the thread above for your automatic notation.
If you have a more specific example to share, perhaps the community can help you write it.
eyal.dekel
  • Sep 11, 2025 7:03 PM UTC
Hi David,
Thank you for your prompt response!
Unfortunately, I can’t share my design (company confidential).
I can send you some example like ‘double gauss’, but if the solution is relevant only for that lens, I don’t believe it will help me.
Eyal
