Efficiency Tips & Tricks for OpticStudio
  • Sep 2, 2020 6:02 PM UTC
  • 39 replies
  • 5062 views
Show first post
yuan.chen
  • Jan 22, 2021 10:54 AM UTC
Add your topic to favorites
yuan.chen
  • May 18, 2021 3:27 AM UTC
To obtain POP image on shaded view, you can:
  1. Open the POP settings to save the .ZBF file at all surfaces, please make sure that the .zbf file you save has the same name as the .zmx
2. Select the surface you want to show, go to the physical optics-> check draw fiber coupling on shaded model
3. Open shaded model plot
Something I just discovered this morning, is that if you click on the Material cell of a surface with a catalog glass, and then open the Libraries..Materials Catalog, it automatically opens at the right page, displaying all the relevant information of that particular glass without having to search for it :)
Saddly, this does not seem to work in non-sequential mode.
Hi David
It seems to work for me in non-sequential mode too. Would you mind checking again?
Sandrine
Hi Sandrine,
I have setup a non-sequential file with a single Standard Lens object (default parameters) made of N-BK7. If I click the Material cell, and open the Materials Catalog, it goes to AMTIR1 from the AMTIR.AGF catalog. I guess because its the first one in alphabetical order. I'm running the May 24, 2021 version (21.2).
Hi David
I can't seem to be able to reproduce the issue. If I am on the material column, then opening the Materials Catalog opens the right material. I am testing in 21.2 too. I'll ask someone else to have a look. I might be missing something.
Sandrine
Thanks for looking into that Sandrine, but just to let you know that it doesn't bother me. It is just something I noticed.
Sahil
  • Visible
  • Jun 23, 2021 1:49 PM UTC
Hello David,
Thanks Sandrine for letting me in . I have tested in OS build 21.2 and it seems working fine . On clicking on Material column it opens correct material .
Sahil
Hi Sahil,
Thanks for checking, you did it for non-sequential right?
Anyway, I don't mind, maybe its just my installation which is faulty.
The point is rather that its a cool feature to know about :D
Sahil
  • Visible
  • Jun 23, 2021 2:42 PM UTC
Hello  David,
Yeah I did in Non sequential editor. Yeah could be David
Thanks
Jay.Bernal
  • Feb 1, 2024 9:03 AM UTC
Hello! Is there a way to temporarily ignore or disable an object in Non-sequential mode? Is there a shortcut key for that?
perform arithmetic operations directly in the cell: works for addition, but not subtraction
  • Apr 3, 2025 5:56 PM UTC
​@David.Kappel There are 2 ways you can subtract:
  • Use a plus before the minus +-5
  • Use a space between the minus and the number - 5
Both techniques will subtract 5 from the cell.
(image credit to Erin Elliot)
thanks…
