Designing off-axis parabolic mirror with coordinate points
  • March 21, 2024
  • 167 views
saif
Dear Experts
I have calculated two end coordinate points of an off-axis parabolic mirror lets say (184, 13.5) and (217, 18.8), may i ask if i can design this mirror in zemax by using these coordinate points and focal length of 200 micron.  Please advise
All units are in micrometer.
sincerely
saif
Hi Saif,
There are two way that can be used to make Off axis mirrors!
  1. You can define the aperture (rectangular, circular etc.) and off axis distance from surface setting tab under aperture section. Off axis distance will decide the offset from center of parent mirror and defined aperture will decide the size (geometry) of OAP.
  2. If you have complex geometry (Hexagon etc.), you can define a "User defined aperture" based on your coordinate points and apply the defined aperture to parent mirror.
Hope this helps!
Thanks.
saif
  • March 25, 2024
Hi Chandan
Thank you for clarification.
Sincerely
saif
