Creating Thin Film Tapers
  • June 14, 2023
  • 243 views
William Oak
I want to share this because I wasnt able to find any information on it in my original searches and the help is a little confusing on the requirements. I’ll use the PT (polynomial) taper as an example since its what I used.
To start with, an important element to remember is that anything in the coating has to come before it in the coating.dat file-so both the TAPR and the MATE have to be before the COAT to function properly.
For each PT line, the first element is the order (x^2, x^1, etc) and the second the coefficient. As such, order zero defaults to 1, so it can be excluded here, but knowing its one is important for understanding how to generate coefficients. My initial error was that the coefficients (C2, C1, C0) where as follows, with a thickness d and a position x (in this case, looking at a single axis):
C2*x^2 +C1*x +C0=d(x)
However, this is inexact. For TAPR coefficient (g2, g1, g0) its more accurately the following:
d(0) * (g2*x^2 + g1*x+g0)=d(x)
To compare with the previous formulation:
g2=C2/C0=0.001, g1=C1/C0=0.02, g0=1, d(0)=10
Hopefully this can save someone else the time it took me to figure this out.
James.Fry
  • June 29, 2023
Totally agree regarding TAPRs and proper implementation.  Took me a while to figure them out, too.  Now go on and tolerance the layer thicknesses!
William Oak
  • July 10, 2023
Yeah, I’m working on a macro to be able to do the tolerancing. Still, before I realised that tapers existed, I thought I’d need to make a macro to vary coating thickness according to position!
James.Fry
  • July 10, 2023
These are recent tolerancing additions you might want to check out if you haven’t already:
TCMU: Tolerance on Coating Multiplier
TCIO: Tolerance on Coating Index Offset
TCEO: Tolerance on Coating Extinction Offset
William Oak
  • July 10, 2023
Thank you very much! I’m fairly new to managing coatings, so this is very useful.
