Service Pack
OpticStudio 22.2.1 Release Notes
  • Aug 2, 2022 7:44 PM UTC
  • Aug 3, 2022 9:33 PM UTC
  • 1321 views
Tom Pickering
August 3rd, 2022
OpticStudio 22.2.1 contains the following fixes and enhancements.
Feature Enhancements
  • Project Directories – support was added for DLL\PhysicalOptics (.DLL) files and Objects\Sources\Radiant Source Model Files (.RSMX) files.
Bug Fixes
  • Q-Type Asphere surface – Fixed an issue with the Scale Lens tool incorrectly scaling the Q-Type Asphere Norm Radius.
  • Image Simulation, Geometric Bitmap Image Analysis, Geometric Image Analysis – Added warning messages to three analyses (Image Simulation, Geometric Bitmap Image Analysis, and Geometric Image Analysis) for situations where the Field Type is not Object Height.
  • Reverse Elements tool – Fixed an issue with the Reverse Elements tool failing to reposition the Stop at the correct surface.
  • Export to Speos Lens System tool – Fixed an issue with the Export to Speos Lens System tool incorrectly reporting high divergence values.
  • Coordinate Break surface - Fixed an issue where pickup solves that point to the thickness of a mirror surface would return 0.
  • Export to Speos Lens System tool – Fixed an issue where the Export to Speos Lens System tool would crash OpticStudio if the file name of a Black Box file exceeded 32 characters
  • Non-Sequential Component Editor – Fixed an issue where the Diffraction section of the Object Properties wasn’t grayed out for the Rectangular Volume object.
