I am working on a project with multi configuration object, object type is object height, normalization is rectangular, and each object data define by YFIE, XFIE, FLWT in multiconfiguration editor, also each object had different thickness defined by THIC. When I simulate my project in ZEMAX, it works fine, all rays pass through STOP aperture. But when I converter it to Creo, the rays came out to different direction, not all pass through the STOP aperture, just terminated at the source surface.
And when the Creo file be opened, it only can show one config at a time, can’t show all config together.
Anybody tried this before? Or has any idea what the problem is? How to solve it?
Thank you!
Best answer by mojtaba.falahati
