Service Pack
OpticsBuilder 23.2.01 Release Notes
  • Aug 2, 2023 10:26 PM UTC
  • 108 views
Lisa C
August 2nd, 2023
1 Bug Fixes
Zemax OpticsBuilder 23.2.01 includes the following bug fixes:
  • Import ZBD File -
    • In Creo 4, a sample system was not visible in the graphics area after importing the same system multiple times in a row.
  • Update ZBD File -
    • Reference geometry remained after Update ZBD File when the same initial system has been chosen.
  • Optics Manager -
    • In the Optical Properties menu, available optical component types were not listed in alphabetical order in the “Object Type” list.
    • There was a 10 second delay during the preview for some lenses when changing parameters for the part.
    • In some cases, the name of a source would not change in the Optics Manager after the component type was changed in the part parameters.
  • Scatter Models -
    • The scatter models for all faces of an object were not correct after the lens was opened in part mode.
  • Miscellaneous -
    • UI: When entering part move, the selection list was still active.
    • The “Add Mounting Edge” tool would show more than the selected object in the editing window, in some cases.
    • UI: Sometimes the Chief Ray object would not appear in the Creo Model Tree after selecting the Chief Ray in the graphics area.
    • The DLL folder would appear empty after installing OpticsBuilder.
