OpticsTalk: Flash LiDAR in new iPad Pro and its Modelling
Userlevel 1
Badge
Here's the discussion space for the OpticsTalk: Flash LiDAR in new iPad Pro and its Modelling, to hosted by Zemax Senior Optical Engineer, Sandrine Auriol.
Apple introduced flash LiDAR in the new iPad Pro for AR applications. Join Sandrine in this talk to discuss the principle of flash LiDAR and methods of modeling it in OpticStudio. Stay tuned on this forum thread for updates and discussion after the talk!
Please add a way to show how a Diffractrive optical element (DOE) / DOT projection can be used to recreate a whole scene with a distance/amplitude information rather than a single conical source. Speaking of real world scenario accurate distance and amplitude info is of importance while calibrating the sensor. Also, in Ipad it is dTof it would be interesting to see iTof as well. In addition, adding a modulating source file native to Zemax would be great.
Thanks
Userlevel 5
Badge +2
Thank you all for attending this tech talk. I have attached the presentation slides and I have copied some useful links:
How to create a Time-Of-Flight User Analysis using ZOS-API
Batch Processing of Ray Trace Data using ZOS-API in MATLAB or Python
How to use importance sampling to model scattering efficiently
Learning Path - Getting started with ZOS-API
Thank you.
Sandrine
Userlevel 5
Badge +2
Hi Zain Ali,
We don't have any models to share right now, but for the dot projection you may find this link useful: https://www.lighttrans.com/use-cases/application-use-cases/working-principle-demonstration-of-dot-projector.html
Sandrine
