Problem regarding Installation
  • September 21, 2021
  • 7 replies
  • 355 views
I just installed OpticsStudios and the problem is always the same. All is working perfectly but i can’t undo things. At each manipulation, a warning message shows :”Unable to find Undo file”. And i tried to resinstall my Matlab multiple times but the problem persists. My “Undo” file is empty in the Data folder or in the Program folder.
Do you have a solution ?
Cordially,
Emmanuel
  • 157 replies
  • September 27, 2021
Hello!
Unusual issue. I suspect the “UNDO” folder doesn’t have appropriate permissions to write the files. Can you send a screenshot of Setup > Project preferences > Folders as below so I can see where the rest of your DATA file are located?
Francisco
  • Student
  • October 6, 2022
Don Dickinson wrote:
Hello!
I have the same issue and I have the correct path to UNDO C:\Users\pacov\Documents\Zemax\Undo
Francisco
  • Student
  • October 7, 2022
I have this folder. I don’t find the mistake. Someone can help me?
Can you save a plain text file into the UNDO folder? If that fails then it is a permission problem on that folder. That’s unusual though as /user/Docuemnts should be full  control for that user. Anyway, it will resolve whether permissions are the issue.
Does your company have any specific security settings for standard users? You may have some IT policy in place that is preventing access
Francisco
  • Student
  • October 10, 2022
I can save a plain text file in UNDO folder. I still have the error.
  • 157 replies
  • October 12, 2022
Hello!
Thanks for pitching in Mark!
I wonder if this is just a corrupt file or Undo database? I’d try closing Opticstudio and deleting everything within the ”UNDO”  folder. Then see how things work going forward.
Francisco
  • Student
  • October 13, 2022
Hello!
I deleted the files in UNDO and then I could made a change in a file but later I got the same message error “Can’t open file ...”
