New ansys floating license - how to install on two machines (Laptop and Desktop)?
Hello all! I just changed to an Ansys  floating license. I was able to install the Ansys server on my descktop and to create the licensing file though their licensing portal, so that the software is working now.
Now I wanted to install the software to the Laptop by the same procedure, but it seems that I am not able to have two servers registered, and that the licensing file does only work for one server, which is locally running on my desktop.
How do I get the license run on my Laptop, too?
Thanks a lot in advance!
Karen
Best answer by Don Dickinson
Hello!
Yes you can only activate one machine. Ansys licenses are network / floating licenses which are available to other computers on your network. You can configure Opticstudio on your laptop to find the machine you activated.
https://support.zemax.com/hc/en-us/articles/6621344879123
If you need to use the license when not connected to your network you can also “borrow” it for up to 30 days at a time.
https://support.zemax.com/hc/en-us/articles/12705804352659-Borrowing-an-Ansys-network-license-for-offline-use-with-Zemax-applications-
  • 157 replies
  • April 5, 2023
Hello!
  • April 22, 2023
Hello, thanks for the answer. But this does not solve my probelm. since I do not have a server available, but run the license locally on my computer, the linked manual does not help with my issue. How do I access the license on my computer fomr the leaptop while I am logged into my local network?
Hello!
I already addressed this - The machine you activated is effectively the server. You configure Opticstudio on your laptop to find the activated machine over the network. It’s usually just a matter of entering the other computer’s name into the settings.
