ZPL Macros slow zemax drastically down
Good day everyone,
I have a problem concerning the speed of the raytrace (I think) when using a simple ZPL, that should be
calculated before the raytrace. The ZPL’s look like this
SOLVEBEFORESTOP
p = PARM(0,0)
q = (p>123.8) * (0.7688*p*p + 0.035*p - 21) / 1000 - (p<=123.8) * 1/1.203
SOLVERETURN (q)
They take a single value and calculate a single value which is placed in the corresponding Lens Data cell.
My file has 9 Configuratins, which change the parameters used by the ZPL’s.
When I don’t use the ZPL-Solves, the File runs fine. When I start using the 6 ZPL’s I need, the evaluation slows
down significantly (20cycles / 8s down to 1cycle / 8s when optimizing). It is generally slow due to the inefficient use of Multi-Configurations and is not the problem I need help with tackling at the moment.
Can anyone tell me, why this slows Zemax down so significantly and how I can avoid this slowdown?
Best regards!
Best answer by MichaelH
Can you try to add SUSPENDUPDATES before SOLVEBEFORESTOP?  This keyword will prevent any ZPL code from causing a UI refresh and often speeds up a ZPL.
Curious to hear answers to this question. You may need to upload an example file at some point. Also:
p = PARM(0,0)
is likely to return 0.0 every time (because I don’t think there’s a Parameter 0). Not sure if it is intended.
Ansys Staff
  • Ansys Staff
  • 376 replies
  • July 12, 2022
