ZOS-API- How can I change the settings (e.g. apodization..) of the System Explorer?
  • Sep 30, 2019 2:45 AM UTC
  • 141 views
Julia
For example, If I want to:
  • Set apodization type as Gaussian, use the enumeration ZOSAPI.SystemData.ZemaxApodizationType.Gaussian.
  • Set Apodization factor as 1
  • Untick Fast Semi-Diameters
  • Tick Adjust Index Data To Environment
The following code can be used:
TheSystemData.Aperture.ApodizationType = ZOSAPI.SystemData.ZemaxApodizationType.Gaussian;
TheSystemData.Aperture.ApodizationFactor = 1;
TheSystemData.Aperture.FastSemiDiameters = false;
TheSystemData.Environment.AdjustIndexToEnvironment = true;
If I want to:
  • Set Coating File as COATING.DAT
  • Set Scatter Profile as SCATTER_PROFILE.DAT
  • Set ABg Data File as ABG_DATA.DAT
  • Reload above data files
  • Add Title and Notes
TheSystem.SystemData.Files.CoatingFile = 'COATING.DAT';
TheSystem.SystemData.Files.ScatterProfile = 'SCATTER_PROFILE.DAT';
TheSystem.SystemData.Files. .ABgDataFile = 'ABG_DATA.DAT';
TheSystem.SystemData.Files.ReloadFiles();
TheSystem.SystemData.TitleNotes.Title = 'Add here the title';
TheSystem.SystemData.TitleNotes.Notes = 'Add here the notes';
