zos-API exporting FFT MTF results
  • April 21, 2026
  • 89 views
nzin
Hi All,
I’m trying to use python to export data from the FFT MTF analysis. I want to export data only up to 20 lp/mm, but when I try to do this, I only get a series out to 40 lp/mm. I also tried a different frequency above 40 lp/mm, and it only will output the data out to 40 lp/mm.
    newWin = TheAnalyses.New_FftMtf()
    newWin_settings = newWin.GetSettings()
    newWin_settings.MaximumFrequency = 20
    newWin_settings.SampleSize = ZOSAPI.Analysis.SampleSizes.S_128x128
    newWin.ApplyAndWaitForCompletion()
    newWin_Results = newWin.GetResults()
    data = newWin_Results.GetDataSeries(1)
    xRaw = data.XData.Data
    x = np.array(tuple(xRaw))
    print(x)
Does anyone know how to make it so that I only get data up to a specified frequency?
  • April 22, 2026
@nzin
I adapted your code for ZOSPy (2.1.5) and tried it on the Double Gauss 28 degree field sample file.
import numpy as np
import zospy as zp
zos = zp.ZOS()
oss = zos.connect("extension")
newWin = oss.Analyses.New_FftMtf()
newWin_settings.MaximumFrequency = 12.3
newWin_settings.SampleSize = zp.constants.Analysis.SampleSizes.S_128x128
print(np.max(x))
I used a frequency of 12.3 to be extra sure it wasn’t a sort of default value.
The script output is (only printing maximum of x):
Maximum frequency: 12.3
I am using 2026 R1.
Perhaps you have a file to share with us that we can try with the script?
