Zernike standard phase. Coefficients 7 and 8 issue.
  • Sep 20, 2024 3:11 PM UTC
  • 441 views
mpreciado
I have been tring to reproduce the phase produce by the Zernike standard phase, and I believe there is an issue with the terms 7 and 8, corresponding with vertical and horizontal coma.
Theoretically they should be
Z7=sqrt(8)*(3*ro.^3-2*ro).*sin(phi);
Z8=sqrt(8).*(3*(ro.^3)-2*ro).*cos(phi);
However, after a lot of headache I realized that they behave like:
Z7=sqrt(8)*(3*ro.^3).*sin(phi);
Z8=sqrt(8).*(3*(ro.^3)).*cos(phi);
Ithought maybe it a different stardard, but in the original paper referred
R. Noll, "Zernike polynomials and atmospheric turbulence", J. Opt. Soc. Am., Vol. 66, No. 3, p207 (1976)
The definition is sqrt(8)*(3*ro.^3-2*ro).*sin(phi).
It is pretty obvious noticing that radially is just a cubic term without the linear term when you represent the wavefront map. It does like the 7th (or 8th) order zernike represented in many places.
This is very surprising. Anybody else noticed this issue?
I am using Ansys Zemax OpticStudio 2023 R2.02.
Miguel
ZEMAX 7TH ORDER ZERNIKE
MATLAB USING THE STANDARD FORMULA:
MATLAB USING THE “WRONG” FORMULA (Result simialr to zemax):
sqrt(8)*(3*ro.^3-).*sin(phi).
Representation of vertical coma in other sources (result similar to matlab with the standard formula):
http://optics.udjat.nl/monochromatic_eye_aberrations.htm
Best answer by Chris Normanshire
Hi Miguel,
Thanks for the question. I think the issue here is that you are comparing the surface phase computed by the formula to the wavefront map, which shows the OPD in the exit pupil referenced to the chief ray. If you instead use the Surface Phase plot then you can directly see the phase of the Zernike surface which matches expectations.
If you want to see a similar profile on the Wavefront Map then you can set System Explorer...Advanced...Reference OPD to ‘Absolute 2’. This removes the chief ray reference and computes the OPD directly at the image surface.
I hope this helps.
Chris
Chris Normanshire
Hi Miguel,
I hope this helps.
Chris
