ZEMAX unable to handle light sources 10^15 away.
  • Mar 28, 2022 1:09 AM UTC
  • 186 views
DDDD
    When I set the distance from the Source Guassian to 10^15 , NSC 3D Layout shows that Maximum zoom has been reached.
    Is zemax unable to simulate this kind of problem ?
Best answer by yuan.chen
Hi , we often use a value of 9e9 for “infinity” when it comes to ray distances. This option may help to solve the problem but pay attention to the unit change in this case.
yuan.chen
  • Mar 28, 2022 1:59 AM UTC
DDDD
  • Visible
  • Mar 29, 2022 1:39 AM UTC
Thanks for your reply !
Does it mean that when it comes to distance more than 9e9 you will have to use INF in ZEMAX ?
yuan.chen
  • Mar 29, 2022 2:27 AM UTC
Hi, honestly I am not certain about this. What I mentioned in my last reply is an exchange I got from our developers. I think one way to check is to use different distance value and see the difference between different distances.
DDDD
  • Visible
  • Mar 29, 2022 8:38 AM UTC
 OK.THANKS AGAIN FOR YOUR HELP .
