working with Non-Sequential Component CAD part
  • May 16, 2025 9:08 AM UTC
  • 143 views
I’m working in sequential mode with a nonsequential component, which is a CAD part (stp). It’s a quite complex part which I exploded into 13 parts. When I change something (like assigning a material or scaling a part) the program freezes and it takes approx.. 2 minutes loading until I can do anything again, although I disabled the auto-update of all windows. When I update the shaded model the whole program freezes and around 10 minutes later it finishes loading.
I already deleted all unneccessary parts and neither the working memory nor the cpu are at full capacity.
Does anyone have any ideas on what I could do to be able to work smoothly (or even just a little more smoothly) with complex cad files?
Thanks in advance for any help!
​@Lea.Sauerwein
Hard to comment on your specific case without a file. It doesn’t answer the question but my advice would be to think about what you wish to achieve with your file. Some time ago I wrote about this topic in the accepted answer of this post (Section: Model Accuracy vs Appearance):
Do you really need the 13 CAD parts in the mixed (sequential/non-sequential) system or is it just for rendering/convenience? Can any of the CAD be (partially) replaced with native objects? What analysis are you interested in sequential mode?
