Why the NSDD curve in universal plot 1 D is strange when use non-sequential mode?
  • Oct 14, 2022 3:33 AM UTC
  • 410 views
Lenror Li
Hello, When I run a universal plot 1 D in non-sequential mode, why is the curve of NSDD so strange as follows?
At Z Position = 0.0, your Detector Rectangle is basically overlapping with your Source.
At Z = 0.0, the Detector Rectangle is at the same position as the Source (in orange).
Therefore, NSDD returns zero. When you go to negative values, your detector is behind the source, so NSDD continues to return zero. Only with positive values >0 and <10 does NSDD return sensible values, although the detector is between the lenses and the source (which probably doesn’t make sense). The jump that you observe is because the Detector Rectangle goes from not seeing anything (because it is colocated with the source) to a divergent Gaussian beam.
I see that by default, your Detector Rectangle has a Z Position of 106.0. If you want to move about this position, you need to use a Start/Stop value of 96/116 respectively (this is +/-10 around 106):
I hope that makes sense.
Any chance you can share this file with us for troubleshooting?
What does the Detector look like at the “strange” positions?
Lenror Li
  • Visible
  • Oct 17, 2022 2:58 AM UTC
Hello, David
         The following is another file I tested, the merit editor value and the universal plot 1 D is also different. I have attached the file.
  • Oct 18, 2022 9:22 AM UTC
Lenror Li
  • Visible
  • Oct 18, 2022 11:20 AM UTC
Hello, David
        Thanks, got it, I misunderstood the meaning of start value.
Lenror
