Why paraxial lens cannot simulate optical path difference and resulting phase difference accurately?
  • Aug 7, 2024 3:58 AM UTC
  • 287 views
Borui
I build a simple model with a Source Ellipse, two paraxial lens with the same f and spaced 2*f apart. So in theory from Source Ellipse are first focused by the first lens and then we can get a plane wave after the second lens. If we put a detector after the second lens, all rays hitting the detector should have the same coherent phase, but that's not the case.
Best answer by David
The issue involved, along with a solution, is discussed here.
Borui
  • Aug 8, 2024 9:00 AM UTC
details are shown as following
Borui
  • Aug 8, 2024 9:02 AM UTC
Because I need to analyze the wavefont of a flys eye array, I plan to combine many paraxial lenses as an array. However this problem shocked me😥
  • Aug 9, 2024 9:35 PM UTC
