Why MCSD affect the thermal analysis result?
  • Nov 6, 2024 10:11 AM UTC
  • 157 views
When i make Thermal to analysis the optical performance (MTF..), the value of MCSD will affect the results.
When i set the MCSD>SDIA, the thickness value of air gap will be different.
Do you know how the MCSD affect the calculation of air gap thickness?
  • Nov 7, 2024 4:40 PM UTC
The MCSD itself doesn’t affect the air gap spacing but actually the combination of the SDIA+CHZN.  The following article has an illustration showing the 4 different combinations of SDIA/CHZN/MCSD.
https://www.linkedin.com/pulse/monte-carlo-thermal-analysis-michael-humphreys-rghrc/?trackingId=qYxBSM4noZk9kMMmO%2BdIVg%3D%3D
