Why is it that thermal pickup does not update the crvt and thic?
  • May 19, 2022 2:39 PM UTC
  • 256 views
Thermal pickup does not update surface curvature and element thickness variations with temperature for some reason. Sharing a snippet of the difficulty:
What are some possible explanations?
Best answer by MichaelH
Have you increased the number of decimal points (Setup > Project Preferences > Editors > Decimals)?  Sometimes the TCE of the material is small so you can’t see the change with the default of 3 decimals.  Also, what’s your material?  If you’re using a glass, the TCE in the Material Catalog should be greater than 0 and if you're using a MIRROR, then the TCE in the LDE should be greater than 0.  Finally, to properly calculate the spacings/ring contact, OpticStudio also needs to calculate the change in clear semi-diameter (SDIA), so you should also include this operand.  It's recommended to use the Make Thermal tool (in the MCE toolbar) to properly populate the MCE with the correct operands.
  • May 19, 2022 6:20 PM UTC
  • May 20, 2022 9:03 AM UTC
Thanks @MichaelH . Increasing the decimal points did the trick. Pickup calc matched with hand calculations. Both elements are fused silica. Noted on SDIA and tool recommendation.
