Why I can't see anything in the layout?
  • Dec 24, 2021 8:36 AM UTC
  • 10 replies
  • 1491 views
Kevin Chen
Hi all,
I am really new in Zemax, learning from the tutoral and found out that why I couldn’t see anything in layout (Cross-Section) when I open after I set all the proper parameter?
Even I tried to optimize all the system, the variable didn’t change, not sure if this related to the same problem?
I also have tried some example documents from the Zemax file and the problems are the same.
Best answer by Jeff.Wilde
So the layout is still not working?  Try opening the attached file.  I’m also using the latest version (21.3.2).  A couple of layouts (cross-section and shaded model) should automatically load.  If they still don’t work, then I suggest you contact technical support.  There may be some issue with your graphics card and/or graphics driver.
  • Dec 24, 2021 7:05 PM UTC
What is your aperture setting?  If zero, change it to an appropriate non-zero value.
Also, be sure to use enough rays to see the beam in the Layout window:
Kevin Chen
  • Dec 25, 2021 4:15 AM UTC
Hi Jeff,
Thanks for the reply, I’ve tried to increase the number of rays and apertaure. but nothing change… I think I have bumped into really weird situation… I even tried to re-install the software but nothing change too...
  • Dec 25, 2021 4:24 AM UTC
If you attach your file I can take a quick look at it.
Kevin Chen
  • Dec 25, 2021 4:27 AM UTC
Hi Jeff,
Thanks! Please find the attachment.
  • Dec 25, 2021 4:42 AM UTC
I opened your file and see that, for some reason, the layout window does not display properly.  So, I just closed it and opened another version, and it works fine.
You can also try 3D Viewer and Shaded Model layouts too.
Kevin Chen
  • Dec 25, 2021 4:48 AM UTC
Hi Jeff,
Thanks for the try. So it is kind like a bug of the software? What I am using now is the latest version of OpticsStudio. I also tried the other 2 options but they display my setup too….
  • Dec 25, 2021 5:05 AM UTC
Kevin Chen
  • Dec 25, 2021 5:24 AM UTC
Ok both two layout are still blank, I will try to contact the Zemax support, thanks!
Hello @Kevin Chen, I have the same issue you presented in this discussion one year ago. Could you tell if and how you fixed it please?
Manon
Chanitti
  • Mar 20, 2023 10:55 AM UTC
Hi @Manon.Lallement, It also happend for me today. Could you tell me if and how you fixed it please?
