Why does the wavefront of Cassegrain-type Ritchey Chretien telescope have a hole in the center?
  • Jun 6, 2022 2:29 AM UTC
  • 6 replies
  • 854 views
DDDD
  When I found that the wavefront of  the image surface of Cassegrain-type Ritchey Chretien telescope to have a hole in the center (as shown below) , I wonder how it is formed.
  Thanks a lot if anyone can explain it  !
Hi DDDD,
I’m not exactly sure without seeing your system in more details, but typically, the secondary mirror obscure the central portion of the incoming ray pencil. Thus creating a “hole” in the wavefront.
Perhaps this picture from Vladimir Sacek (found on his website) can help:
Ignore the text, just look at the beam path in yellow. Do you notice the missing cone after the secondary mirror? This is why the wavefront can’t be calculated.
I hope this helps.
  • Jun 6, 2022 9:33 AM UTC
Hi DDDD,
I hope this helps.
DDDD
  • Visible
  • Jun 6, 2022 12:26 PM UTC
Hi DDDD,
I hope this helps.
Hi David :
  Thanks for your help !
DDDD
  • Visible
  • Jun 7, 2022 1:40 AM UTC
Hi DDDD,
I hope this helps.
Hi David :
  I have some further questions , hoping that you may help.
  I now need two telescope to intefere  ,I expect the result to have no hole in the center.
  I think after the process of focusing , the result should be a point, the wavefront should have no “hole”. But the result seems to have a “hole” in the center.
Sincerely
DDDD
DDDD
  • Visible
  • Jun 7, 2022 12:54 PM UTC
This is the file I used.
Hi DDDD,
You need to give us more details about what you are trying to achieve. I downloaded your file, but there’s only one telescope in it, as far as I can tell.
Let me know if I’m overlooking something.
DDDD
  • Visible
  • Jun 11, 2022 8:42 AM UTC
Hi DDDD,
Hi David :
   The  result after intefering should have no “hole”. I used the inteference formula to get the inteference result of two identical focused wavefronts but it has “hole” so I am confused.(So I just used one zmx file as shown above.)
Sincerely
DDDD
