Why coating is not working in this file?
  • September 22, 2023
  • 141 views
icybird
Due to the large NA of the input (POP gaussian waist very small), I saw a lot of loss at the front surface of the 1st silicon lens. I would like to see how AR coating is helping, but found out no matter what coating I set the POP doesn’t see it. Is this because I am not using Polarization?
Thanks.
Best answer by David
Yes. That is a possibility. Polarization calculations are required on modeling coating effects.
  • 337 replies
  • September 23, 2023
