Weight configurations differently
  • September 3, 2020
  • 543 views
John.Hygelund
Is there any easy way to weight configurations differently when using the optimization wizard?
Best answer by Angel Morales
Hi John,
Are you already using the CWGT multi-configuration operand? This would be the most straightforward way to define different weights for different configurations, and it will be taken into account when you use the Optimization Wizard:
If the merit function was already built, then you would need to clear your Merit Function Editor and re-build it after the CWGT operand has been defined with the desired weights. Otherwise, you would have to manually update the weights of each operand individually.
Let us know how these thoughts work out for you!
~ Angel
Angel Morales
Hi John,
~ Angel
John.Hygelund
Aweomse! I wasn't aware of CWGT. Thank you.
