Wavelength not in range for ignored objects in sequential mode
  • May 21, 2025
  • 65 views
Randall
I am using configurations to combine multiple arms over a wide wavelength range so I can make sure everything lines up exactly.  I am using a black box lens from a vendor.  The glass in that lens does not work with a wavelength I am using in a different arm.  That black box lens is ignored when the system has the wavelength in question, but this still causes the “Not within valid range” error for the glass.  Is there a way to get around this?  Since it is a black box lens, I can’t go into the glass catalog to make the range larger.
Randall
  • May 22, 2025
Found a workaround: Make a configuration after it that removes the comments from the black box model, which unloads the black box
