Use "Insert Lens" in ZPL macro?
  • May 3, 2022
  • 337 views
Maria
Hi!
I am trying to use "Insert Lens" function (from File tab) in a ZPL macro. Has anyone seen a keyword for it in ZPL?
Thanks!
Maria
Best answer by MichaelH
As a follow-up (too early in the morning, brain wasn't working), you can use the LOADLENS keyword with the appendflag indicating which surface you want to insert the new file at in the LDE.
  • May 3, 2022
Hi Maria,
There is no equivalent in the ZPL but you can use the ZOS-API to accomplish this.  You can use the built-in function from the Lens Catalog tool under the Libraries tab (TheSystem.Tools.OpenLensCatalogs()), but this will only allow you to insert a lens from a ZMF vendor catalog.  If you want insert a custom ZMX/ZOS file, you can create 2 IOpticalSystem using the same connection and then use TheSystem.LDE.CopySurfacesFrom() to copy the surfaces from one optical system to the other.  Below is Python code to achieve this second suggestion:
import zosapi, os
# connect to OpticStudio
zos = zosapi.App()
# create a second system
zos.TheSystem2 = zos.TheApplication.CreateNewSystem(zos.ZOSAPI.SystemType.Sequential);
# load the files: TheSystem will be the main file and TheSystem2 will be the file you want to insert
zos.TheSystem.LoadFile(os.path.join(zos.TheApplication.SamplesDir, r'Sequential\Objectives\Double Gauss 28 degree field.zmx'), False)
zos.TheSystem2.LoadFile(os.path.join(zos.TheApplication.SamplesDir, r'Sequential\Objectives\Doublet.zmx'), False)
# copy the surfaces into the main system
zos.TheSystem.LDE.CopySurfacesFrom(zos.TheSystem2.LDE, 1, zos.TheSystem2.LDE.NumberOfSurfaces - 2, 1)
# save system & verify
zos.TheSystem.SaveAs(os.path.join(zos.TheApplication.ZemaxDataDir, 'insertlens.zmx'))
  • May 3, 2022
Maria
  • May 6, 2022
Thank you, Michael!
