Uploading my .bmp file for image simulation
Is it possible to upload my own .bmp file for image Simulation analysis? IF so where in the directory structure must i save the .bmp file so that it is vissible in the Image simulation pulldown menu?
Best answer by Ali H
Hi Denis,
Yes, it is possible to use your own BMP file; however, BMP, JPG and PNG files must have more than 1 and no more than 16,000 pixels in each direction. The input files are stored in the folder. This folder is normally located \Zemax\IMAFILES\. You may check the location of your images folder by checking the Folders tab of the Project Preferences:
You may find this Knowledgebase Article helpful:
https://my.zemax.com/en-US/Knowledge-Base/kb-article/?ka=KA-01359
Ali
Ali H
  • Visible
  • June 26, 2020
Hi Denis,
Ali
Cheers!
