UDA mechanical semi diameter
  • Aug 30, 2022 9:39 AM UTC
  • 377 views
Is there a way to use UDA while also keeping the required mechanical diameter?
I have a lens like this:
And I want to increase the mechanical diameter (red) and then cut the lens like that(second image below):
right now by using the UDA I got this:
Hope it is clear enough.
Nadav
Best answer by Angel Morales
Hi Nadav,
Thanks for posting on the forums!
When you use a UDA to define an aperture, you lose the ability to define details like a mechanical semi-diameter or chip zone. So, the UDA will only be able to define out to the geometry you define, which is the mechanical semi-diameter, but it will treat it like a clear aperture.
What you could do is to define a dummy surface right before the lens, where the dummy surface has an aperture equal to the clear semi-diameter of the subsequent surface. This would “clip” out potential rays that would land in the non-clear semi diameter region, if that was your intention. This approach is really the only way, as UDA on a sequential surface will remove any mechanical semi-diameter definitions.
If you move to Non-Sequential Mode, though, you could also construct this geometry with something like a Boolean Native object. You could make the lens as normal, then overlap with an Extruded object that contains the UDA file or manually subtract the sides with something like a Rectangle Volume. You can read more about Boolean objects here: How to use the Boolean CAD, Boolean Native and Compound Lens objects, and the Combine Objects tool – Knowledgebase (zemax.com)
Let us know if you have any more questions -- thanks!
Angel Morales
  • Sep 13, 2022 11:33 PM UTC
Hi Nadav,
  • Sep 14, 2022 8:07 AM UTC
Hi Angel,
Thanks for the answer.
Nadav
