Top Hat - collimated beam optimization
  • November 3, 2022
  • 1639 views
Dear Zemax community,
I am building upon your 'How to design a Gaussian to Top Hat beam shaper' tutorial. I additionally want the top hat to be collimated over a 30cm propagation distance.
I setup the system with two aspheres and an optimization macro that squares my beam (REAY operand, as in the tutorial) and subsequently collimates it with the RANG operand (target is 0 angle). However, it fails to maintain the top hat shape and collimation over the propagation distance. Am I using the wrong operand to collimate, or should I use the constraints with two dummy surfaces (at a distance of 150mm (MIDPOINT) and 300mm)?
Any suggestions are welcome and appreciated.
Thank you very much, Paul
Hi Paul
Your merit function contains 2 blocks:
  • one to target a uniform / top-hat beam on the image plane
  • one to target collimated on axis rays
This looks correct to me. You could swap the second block with a default merit function and target an angular radius:
So I guess that if it is not working it may be because of the varialbles, maybe the system doesn’t have enough degrees of freedom.
Hi Paul
