Answer
tolerancing birefringent crystals
  • June 10, 2021
  • 165 views
I would like to conduct a sensitivity analysis on the optical axis orientation of birefringent crystals. I am asking the manufacturer to cut a birefringent crystal so the optical axis is at 45-deg w.r.t the optical axis. x-cosine, y-cosine and z-cosine set the optical axis orientation of the uniaxial optical axis. In my case, x-cosine and z-cosine are set to 0.707 and y-cosine is set to 0. To conduct the sensitivity analysis, I thought I'd slightly change those values but I am not sure that is right. Has anybody done this before? any advice please?
Thanks!
Driss
Best answer by Driss.Touahri
Just updating the earlier post. I got it to work. I had the z-cosine macro-solved based on the x-cosine value so they always track together as a sine and cosine of a given optical axis angle. Then all I had to do was to tolerance the x-cosine value. I ran a quick test and the optical axis seems to change correctly.
  • June 10, 2021
