Tolerancing a system with 2 OAP
  • January 22, 2025
  • 293 views
Bozkov
After following the next article: The easiest way to tolerance an off-axis mirror
I have been struggling to manage the tolerances in my system since it has 2 different OAPs and as in the example, I have set one of them as the global coordinate reference
Apart from that issue, I really don't think my coordinate breaks are working properly to tolerance the OAPs (I only want to check the decentered and tilt tolerances).
Lastly, I don't really know why final focus is not hitting the center of the image.
Thanks
Best answer by Chris Normanshire
Hello. I just saw this old post and wanted to share that we have a new feature that will help set up this tolerancing correctly. NEST; Nested Elements and Systems Tolerancing – Ansys Optics
Chris Normanshire
Bozkov
  • January 29, 2026
​@Chris Normanshire Hello Chris, I have both versions, R1 and R2 and can not see this option of nesting group of surfaces. How can I solve it? Is there any alternative way of doing it? In my case, before defining each surface I have a Return to Surface 1 Coordinate Break, in order to simplify the positioning of each element (I have a complex system). But this makes the Nesting of the surfaces harder.
Best regards
Donna.Waters
  • July 29, 2026
NEST is not available to Pro users.
