Tolerance TCE value
  • June 24, 2021
  • 99 views
Is it possible to assign a tolerance to the TCE value of a surface?
I know there is TPAR to tolerance a surface parameter but the TCE value is not a surface parameter that I can tell.
Thank you,
Taylor
Hi Taylor,
I think you could expose the TCE through a ZPL Macro Solve, and then use TPAR. Tolerancing might be a little slow though. Have a look at the example below (I'm also attaching this archive to my post). Otherwise, you could leverage the ZOS-API to perform this tolerancing, but this solution is definitely more involved. I can help you get started if you want to go this way.
