TE and TM polarization source diodes
  • December 6, 2022
  • 200 views
Aparna Dayal
How to design TE and TM polarization laser source diodes in non sequential mode?
Best answer by David
Hi Aparna,
The polarization of a source, for example a Source Diode, can be set in the Object Properties dialog of each individual source. Jx and Jy refer to the initial amplitudes of the x and y components of the electric field. Whether a ray is TE or TM when striking a substrate depends on its orientation with respect to the plane of incidence.
There is a nice article on this here.
  • 336 replies
  • December 6, 2022
Hi Aparna,
Aparna Dayal
  • Student
  • December 7, 2022
Hi David,
Thank you for the explanation.
