String modification (zpl)
  • Dec 16, 2019 4:24 PM UTC
  • 266 views
$FILENAME() returns the file name that includes ".zmx".  I would like to replace "zmx" with "cfg".  Can you suggest a way to accomplish this?
(If I knew the string length, I could use a $LEFTSTRING command, but I cannot find a string length command.)
Thanks.
  • Dec 16, 2019 8:51 PM UTC
you can get the length of the string using the Numeric Function SLEN(), then you can use $LEFTSTRING()  with that length minus four.
I have attached an example macro that does this.
Thanks!
Ah,  I scoured the string function section and missed this one.  Thank you.
Cindy.Chen
  • Dec 31, 2019 4:15 PM UTC
  Filter$ can help filter the CFG format out:
  PATHONLY$ = $PATHNAME()
   PATH$ = PathONLY$ + "\*.cfg"
   FILTER$ = PATH$
   FINDFILE TEMPFILE$, FILTER$
