Stellar inteferometer pattern not changed when baseline changed
  • Jul 23, 2022 11:26 AM UTC
  • 258 views
DDDD
  I made a stellar interferometer using NSC model, but the change of baseline didn't get different interference fringes ,which should not happen .
  I couldn’t figure out why.
Best answer by Jeff.Wilde
The stellar interferometer assumes the object is a star of finite diameter radiating spatially incoherent light.  Light from each point on the star can interfere with itself, but not with light from other points.  The interferometer therefore forms a superposition of numerous interference patterns, one fringe pattern from each point (or small spatial patch) on the star.  These individual fringe patterns are similar in modulation depth, but they vary in relative phase depending on the lateral position of the corresponding source point (on the star) as well as the baseline separation.  The result is that as the baseline increases, the incoherent sum of these fringe patterns causes the net fringe modulation depth to decrease.  In other words, as the baseline increases the elemental fringes combine to “wash-out” the observed fringe.  Some simple math allows one to find the diameter of the star from the baseline separation at which the observed fringe modulation depth goes to zero.
So, with this physics in mind, modeling of the stellar interferometer requires modeling the elemental fringe patterns from *many* pairs of incoming beams (one pair shown in the layout as the blue beam + the green beam).  For each pair of beams, the relative phase between the two individual beams must be set as if the light emanated from a given point on the star.  One way of doing this in OpticStudio is to apply the correct “Initial Phase” to one of the two source in the model to create the appropriate fringe phase shift:
The star can be approximated by a discrete set of mutually incoherent point sources.  Modeling incoming light from across the entire star diameter then requires looping through several slightly different configurations (one for each point source), recording the elemental interference pattern for each configuration, and then incoherently combining them all to get the final result for a single baseline separation.  Then, the baseline can be changed and this process repeated.  So, it is doable, but is best accomplished using a macro to automate the process.
As noted by M. Mansuripur, “The essential idea behind the stellar interferometer is that of a double-slit inteferometer, ...”  (see, Classical Optics and its Applications, 2nd Ed., Ch. 35, “Michelson’s Stellar Interferometer”).  Here is a link to a Knowledgebase article that discusses how to construct an NSC model of a double-slit interfereometer when using an extended incoherent source:  Simulation of Young's interference experiment via geometric ray tracing in OpticStudio.  A modified version could be used to mimic a stellar interferometer.
DDDD
  • Visible
  • Jul 23, 2022 11:30 AM UTC
This is the ZEMAX file
  • Jul 23, 2022 8:15 PM UTC
  • Jul 23, 2022 11:36 PM UTC
@DDDD   One more comment.  In your model the lens units are meters.  Your detector is therefore 4 m x 4 m in size.  For a 500 pixel x 500 pixel detector this means the spacing between pixels is 8 mm.  However, the interference pattern will have a period of about 10 microns.  In order to properly sample this fringe pattern the detector needs to be substantially smaller, on the order of say 5-10 fringe periods.  To make efficient use of the rays, the beam diameters should also be about the same size as the detector.
DDDD
  • Visible
  • Jul 24, 2022 3:10 PM UTC
The star can be approximated by a discrete set of mutually incoherent point sources.  Modeling incoming light from across the entire star diameter then requires looping through several slightly different configurations (one for each point source), recording the elemental interference pattern for each configuration, and then incoherently combining them all to get the final result for a single baseline separation.  Then, the baseline can be changed and this process repeated.  So, it is doable, but is best accomplished using a macro to automatic the process.
Thank you for your detailed answer, it helped me a lot !
