Spectrum File for source file
  • Aug 9, 2021 12:17 PM UTC
  • 943 views
Hi, are there extra steps required so that the colours of the light bulbs are shown when simulating in non-sequential.
Best answer by Sean.Lin
Hi Kai Xin.Soh,
You need to set the parameters of Spectrum in the light source section as shown in the figure below.
Then you need to use the Detector Color. It stores power and tristimulus (visual light color) data from NSC source rays that strike it. The resulting data distributions may be viewed for incoherent light in spatial or angular domains. This object may optionally store the spectral distribution for all NSC source rays that strike it.
Sean | Optical Engineer | Zemax
Sean.Lin
  • Aug 19, 2021 7:15 AM UTC
Hi Kai Xin.Soh,
  • Aug 19, 2021 9:37 AM UTC
Hi Kai Xin.Soh,
Thank you, Sean!
