Source parallelogram
  • August 28, 2022
  • 107 views
Hi all,
Is there a simple way to define a 2D parallelogram source?
edit:
succeed usuing DAT file, and then import as source file:
file1 = open("paraleloid.DAT","w")
Nx = 20
A = 4
B = 12
H = 9
theta = 30
a = A/Nx
h = H/(6*Nx)
dx = h / np.tan(np.pi*theta/180)
Ny = H/h
Ny = round(Ny)
N = Ny*Nx
L0 = str(N) +" "+str(4)+"\n"
file1.writelines(L0)
for j in range(Ny):
    for i in range(Nx):
        L1 = str(round(i*a+j*dx,2))+" "+str(round(h*j,2))+" "+str(0) +" "+str(0) +" "+str(0) +" "+str(1)+" "+str(1)+"\n"
        file1.writelines(L1)
file1.close() #to change file access modes
Nadav
Best answer by MichaelH
Hi Nadav,
Thanks for the post.  I also want to point out you can create any geometry in a CAD software, import this geometry via CAD Part: STEP/IGES/SAT, and then use Source Object to turn the CAD object into a source; this way you can define your source geometry with common practices rather than having to script out a specific shape.  Depending on the software you have and your ability to use CAD, this might be a useful alternative.
  • August 31, 2022
Hi Nadav,
  • September 1, 2022
Hi Michael,
Thanks for the answer.
Nadav
