Smooth in the color Detector
  • October 12, 2023
  • 169 views
Dennis_WR
In a color detector, the same amount of smooth, grayscale, and color get different results. The resulting grid widths are significantly different. I would like to know what is the difference between smooth calculation and normal calculation under color? Which one is more accurate?
Jaroslav.Zadnik
did you find the answer?
Dennis_WR
  • June 25, 2024
Not yet
Jaroslav.Zadnik
Not yet
Can't it be that inverse false color works with some truncated information (for example 8 bit vs 32 bit)?
The color gamut can have multiple levels (thinner lines, more shades)
The inverse false color is already somehow limited - less shade and thus the lines appear thicker
Or you are using some filter ..?
