I’m working on a system in sequential mode where a beam is launched from a multimode fiber (0.12 NA) goes through some lenses, and is focused on an image plane (see my other post on the topic). I had previously asked about how to evaluate the size of the focus after the beam. The suggestion was to put a field point originating from the edge of the fiber (in addition to one launching from the middle of the fiber) and to look at where it lands after the lens - that worked well for that purpose.
Now I would like to know how to evaluate the spot size at a location where the beam is not focused. Using the field height doesn’t work since the rays from all the fields are spread out and partially overlapped. So how would you do this? Is it just a matter of looking at the locations of the marginal rays or is there a better way?
Thanks!
