Simples Lens and layout
  • November 12, 2021
  • 164 views
adewale
I am new to zemax. My first simple lens design did not show up in the lay out. Please I need help. See the result in attached.
Hi Adewale,
I would advise sharing your file as opposed to a screenshot. You can do this by clicking File..Create Archive, put the *.ZAR file into a *.ZIP that you can upload on the forum.
The Clear Semi-Diameter column seem to indicate all zeros. I would advise to press Setup..System Explorer and under Aperture Type, make sure it is set to Entrance Pupil Diameter, and the Aperture Value is set to something greater than 0.
Finally, if you are begining with OpticStudio, have a look at the Knowledge base articles, which have a wealth of information to offer for every level.
Let me know if this helps, and take care,
David.
  • November 12, 2021
Hi Adewale,
David.
adewale
  • Student
  • November 13, 2021
Thanks so much Mr. David, I really appreciate your time and response. However, I couldn’t solve the problem yet. I have created the file as described but I couldn’t attach it here directly. here is the link to my drive simple_lens.
