Simple periscope
  • Jul 5, 2023 8:00 PM UTC
  • 412 views
apbraga
I am trying to model a simple 2-flat mirror periscope using a 2008 version of Zemax. I am not sure how to go about entering a vertical displacement to set the distance between the mirrors. If anyone has any suggestions, I would greatly appreciate.
v/r,
-Alex
Best answer by Benjamin.N
You can use coordinate breaks to build a periscope:
In this example, the vertical displacement between the mirrors is set by the thickness of surface 4.
I have never worked with Zemax 2008, but since this example uses only standard surfaces and coordinate breaks, I guess it should be backwards compatible.
Benjamin.N
  • Visible
  • Jul 6, 2023 4:10 AM UTC
apbraga
  • Jul 6, 2023 3:46 PM UTC
Thanks!
