silicon detector response
  • Jun 30, 2023 8:32 AM UTC
  • 202 views
Aliaksei.Kobylinskiy
Hello! How to add to my NSC design a silicon detector response curve for Color Detector? Maybe simply add a “thin filter” at the top of the detector area having this spectral characteristic, is it appropriate? Or maybe to add different weights for, e.g., 10 wavelengths based on detector response curve. Thanks
Best answer by Mark.Nicholson
Your first suggestion sounds right. Define a TABLE coating with a transmission vs wavelength set by the response curve of the detector, and apply it to the image surface.
Thank you, Mark, for your rapid response! Yes, I understand. Have a nice weekend.
