Seeking to identify cylinder lens issue in Non-Sequential
  • December 12, 2023
  • 154 views
William Oak
I’m currently dealing with a partially afocal system in Non-Sequential mode, where a pair of rod lenses focus light from a gaussian source onto a detector. I’ve been observing a series of lines that I cant explain. They appear after passing through a cylinder lens, and are not present in if I put a detector next to the source
I initially thought it was a sampling issue, but more rays simply made these structures more apparent. I’ve tested two ways of making the cylinder lenses (toroidal lens & cylinder object), no difference. I’ve tested a second source type (two-angle) and got the same result. I’ve also tested removing all elements, and the structure only appears with the cylindrical lenses.
Any idea what could be causing this?
Kevin Scales
Can you attach a copy of a system that shows this behavior, or open a case where you can share the system with us? Without more information, I couldn’t say what might be happening here. Thanks.
