Scattering issue with Boolean object
  • March 25, 2025
  • 154 views
jsung
I created a dome shell object by subtracting smaller sphere from bigger sphere and also removed the rear half with a big cylinder object. This is done with Boolean operation A-B-C (A: big sphere, B: smaller sphere, C: cylinder).
Then I applied Gaussian surface scatter to both side surface (sig=0.25) to make some wide beam angle scatter like tis picture.
But problem when the source is moved to Z=0 where the sphere half plane is, the scattering is gone.
I guess this is caused by source being in the parent object region though parents are shifted away or disabled for ray trace. I tried moving source object below the Boolean object and entered boolean object number in “inside of” column, but that doesn’t make it work either.
I had similar issue with Boolean before when I tried making TIR lens. It was found I should avoid putting the source at the boundary of original parent object or inside. But this scattering issue with Boolean seems like new to me. Any idea if this is a bug or there is way to resolve this?
I couldn’t attach Zar file here (this forum site used to allow that, but now it doesn’t work for me), so I just copied screenshot of NSC editor.
JS
Sven.Stöttinger
I’ve encountered this problem in the past with the boolean native, too. Have you tried using Boolean CAD instead? This worked for me in some cases. Would be great to get this bug fixed, since I find Boolean Native objects incredibly practical to incorporate into my optical models. Unfortunately, Boolean CAD objects do not work in conjunction with diffraction type lenses like Binary 2.
Sven
jsung
  • March 26, 2025
Hi Steven,
Okay, I just tried Boolean CAD in place of boolean native and it worked fine regardless of the source position!
This seems like scattering bug with Boolean native. I find it baffling because Ansys Zemax is describing boolean native as better object for ray tracing accuracy speed than boolean CAD. It should be that way as it consists of native parametric Zemax object, but in current version it seems quite buggy.
JS
