Save and reload results after a timely simulation
When Zemax has run a simulation that takes several hous to complete, it could be a nice feature if the results (raytacing, plots etc.) could be saved and later reloaded into Zemax for further view and comare to other simulations - without having to spend several hours to do the same simation again.
  • 1129 replies
  • January 27, 2021
Hi Rene,
Are you using Include Calculated Data in Session File from System Explorer...Advanced?
It might make your files a lot bigger though.
Cheers,
Tough crowd! If you save your calculated data, it will make your files bigger than if you don't! 😎
Hello Rene!
I think you have some good suggestions here already. Are you talking about non-sequential mode?
In non-sequential mode, you can save ZRD files and also save Detector Data and then replay them.
Sandrine
  • February 3, 2021
Thanks a lot to all of you :-)
