Rotation of a full-non sequential system
  • Apr 18, 2022 8:03 PM UTC
  • 465 views
Nicola Nicassio
Hi, I have a simple question about the possibility of rotating all the elements of a non sequential system together.
In particular, I would need to rotate all the detector elements by an angle of 40° around the y axis. (This would allow me to make a specific axis in my system coincide with the x axis to set polarization easily).
Of course a solution would be to recreate the whole system, but it would be useful to find a command to rotate the whole sysem of a specified angle in case, for example, I would need a rotation of 50° instead of 40°.
Thank you in advance.
Hi Nicola
In non-sequential, there is a tool called Modify Reference Object:
You can change all objects or a selection of objects to be referenced against another object. Then you can apply the rotation on that object.
For example:
Now applying a tilt on Object 1 will affect Object 2.
Let me know if that helps.
Hi Nicola
For example:
