rotate mirror on tilted axis
In NSC, how do you rotate a mirror about a tilted axis? For example, if the orange square below is my mirror in X-Y view, I would like to rotate it by 10 degrees along the axis marked by the dotted line.
Hi Karen,
My pleasure. Don't hesitate to mark my reply as the answer to your question if you've find it helpful. It might also help others.
Hi Karen,
Personnaly, I'd try to use Null Objects as sort of Coordinate Breaks equivalent in non-sequential mode.
Object 1 is a rotation by 45 deg about Z to define your axis of rotation, and Object 2 is a rotation about this newly defined axis, which is now Y (notice the Ref Object is 1). Finally, Object 3 is your Rectangle (Ref Object is 2), and I've just undone the 45 degree tilt of the rotation axis with a pickup so the rectangle is aligned with the X/Y axis. Use the Tilt About Y of Object 2 to tilt about your newly defined axis.
I'm also attaching an archive of my file for you to make sure it is what you want.
For understanding the geometry in non-sequential, I like to open the Object Properties...Draw...Draw Local Axis. This shows how the local axis is aligned with respect to the global X/Y/Z coordinate system.
Let me know if this works for you, and take care,
This worked great - thank you very much!
  • 1129 replies
  • April 14, 2021
Hi Karen,
